Ir para o conteúdo principal
Toilet Keeps Running: How to Fix & Maintain Valve Seat
O que você precisa
  1. Toilet Keeps Running: How to Fix & Maintain Valve Seat, Toilet Keeps Running: How to Fix & Maintain Valve Seat: passo 1, imagem 1 %32
    • Remove the lid from the toilet tank.
  2. Toilet Keeps Running: How to Fix & Maintain Valve Seat: passo 2, imagem 1 %32
    • Flush the toilet, and hold down the flush lever until the tank is completely empty.
  3. Toilet Keeps Running: How to Fix & Maintain Valve Seat: passo 3, imagem 1 %32
    • Gently lift the float up, ending the flow of water. This will prevent the toilet tank from refilling.
  4. Toilet Keeps Running: How to Fix & Maintain Valve Seat: passo 4, imagem 1 %32 Toilet Keeps Running: How to Fix & Maintain Valve Seat: passo 4, imagem 2 %32 Toilet Keeps Running: How to Fix & Maintain Valve Seat: passo 4, imagem 3 %32
    • Pull up the valve seat. If possible, keep it raised without releasing the float.
    • If you do not have assistance, you may need to hold these in place with one hand. This will keep your other hand free for the next step.
    • Some toilets may use a float ball to control overflow.
  5. Toilet Keeps Running: How to Fix & Maintain Valve Seat: passo 5, imagem 1 %32 Toilet Keeps Running: How to Fix & Maintain Valve Seat: passo 5, imagem 2 %32
    • Wipe the valve seat with a rag or towel to remove the calcium deposits. Don't forget to wipe the bottom of the valve seat, as deposits can form there as well.
  6. Toilet Keeps Running: How to Fix & Maintain Valve Seat: passo 6, imagem 1 %32 Toilet Keeps Running: How to Fix & Maintain Valve Seat: passo 6, imagem 2 %32
    • Release the float and the valve seat, and allow them to fall back into place. The flow of water will resume.
  7. Toilet Keeps Running: How to Fix & Maintain Valve Seat: passo 7, imagem 1 %32
    • Place the lid back on the tank.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Roman Snow
Membro desde: 05/05/20
169 Reputação
Autoria de 1 guia
Equipe
3 comentários
Cutting off the water supply, draining the tank and spraying the seat with vinegar or CLR does the same thing -dissolving the calcium carbonate. You can prevent calcium carbonate buildup by putting a piece of magnesium in the tank.
P Schmied - Responder
Thanks for Step #7. Always forget that one!
Matt Heckel - Responder
You may use a calcium remover for toilets. If you have patience and willingness, you can make a DIY toilet cleaner composed of vinegar, lemon, other acidic liquids, and baking soda. Thick calcium deposits in the toilet require muriatic acid and deep scrubbing with scour paper.
lim anna - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 63
Duração total: 780
