Ir para o conteúdo principal
Toilet Flapper Replacement
  1. Toilet Flapper Replacement, Tank Lid: passo 1, imagem 1 %32 Toilet Flapper Replacement, Tank Lid: passo 1, imagem 2 %32 Toilet Flapper Replacement, Tank Lid: passo 1, imagem 3 %32
    • Lift the tank lid up and away from the toilet tank.
  2. Toilet Flapper Replacement, Shutting off the Water Supply to a Toilet: passo 2, imagem 1 %32 Toilet Flapper Replacement, Shutting off the Water Supply to a Toilet: passo 2, imagem 2 %32
    • Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
    • The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
  3. Toilet Flapper Replacement, Draining a Toilet Tank: passo 3, imagem 1 %32 Toilet Flapper Replacement, Draining a Toilet Tank: passo 3, imagem 2 %32
    • Push down the flush lever.
    • Hold the lever down until water stops draining from the tank.
    • A small amount of water will remain in the bottom of the tank.
    • If the flush lever or pull chain have become disconnected, lift up the toilet flapper to drain the tank.
  4. Toilet Flapper Replacement, Disassembling Toilet Pull Chain Spring Clasp: passo 4, imagem 1 %32 Toilet Flapper Replacement, Disassembling Toilet Pull Chain Spring Clasp: passo 4, imagem 2 %32 Toilet Flapper Replacement, Disassembling Toilet Pull Chain Spring Clasp: passo 4, imagem 3 %32
    • Squeeze open the spring clasp that connects the pull chain to the tank lever.
    • Disconnect the spring clasp from the tank lever.
  5. Toilet Flapper Replacement, Flapper: passo 5, imagem 1 %32 Toilet Flapper Replacement, Flapper: passo 5, imagem 2 %32 Toilet Flapper Replacement, Flapper: passo 5, imagem 3 %32
    • Disconnect the flapper from the posts on each side of the overflow tube.
    • Remove the flapper from the toilet tank.
Conclusão
4 outras pessoas executaram este guia.
Kristen Gismondi
Membro desde: 11/12/14
81.925 Reputação
Autoria de 200 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 17.139 guias
2 comentários
Thank you I needed that
My Mama - Responder
How universal is the flapper size? Do I need to measure the existing one before buying a replacement?
John Clements - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 50
Últimos 30 dias: 221
Duração total: 12,266
