Ir para o conteúdo principal
Tofu65 Keyboard PCB Replacement
O que você precisa
  1. Tofu65 Keyboard PCB Replacement, Keyboard PCB: passo 1, imagem 1 %32
    • Unplug the power cord.
  2. Tofu65 Keyboard PCB Replacement: passo 2, imagem 1 %32
    • Use a keycap puller to remove the keycaps from the keyboard.
    • Be sure to pull straight up when removing the keycaps to avoid damaging the key switches.
  3. Tofu65 Keyboard PCB Replacement: passo 3, imagem 1 %32
    • Use the switch puller to pinch the switch on the two pins to release the switch from the PCB.
    • Pull straight up when removing the switch. It should not take much force to pull them out.
  4. Tofu65 Keyboard PCB Replacement: passo 4, imagem 1 %32 Tofu65 Keyboard PCB Replacement: passo 4, imagem 2 %32
    • Remove the plastic cover that protects the PCB.
  5. Tofu65 Keyboard PCB Replacement: passo 5, imagem 1 %32 Tofu65 Keyboard PCB Replacement: passo 5, imagem 2 %32
    • Gently remove the foam layer protecting the PCB.
  6. Tofu65 Keyboard PCB Replacement: passo 6, imagem 1 %32 Tofu65 Keyboard PCB Replacement: passo 6, imagem 2 %32 Tofu65 Keyboard PCB Replacement: passo 6, imagem 3 %32
    • Use a Phillips #000 screwdriver to remove the six 5 mm screws keeping the PCB in place.
  7. Tofu65 Keyboard PCB Replacement: passo 7, imagem 1 %32 Tofu65 Keyboard PCB Replacement: passo 7, imagem 2 %32
    • Remove the old PCB from the bottom case.
  8. Tofu65 Keyboard PCB Replacement: passo 8, imagem 1 %32 Tofu65 Keyboard PCB Replacement: passo 8, imagem 2 %32
    • Ensure your keyboard switches are in good condition and the golden pins are not bent.
    • If the pins are bent, carefully bend them so they are straight or replace them with new switches.
  9. Tofu65 Keyboard PCB Replacement: passo 9, imagem 1 %32 Tofu65 Keyboard PCB Replacement: passo 9, imagem 2 %32 Tofu65 Keyboard PCB Replacement: passo 9, imagem 3 %32
    • Replace your PCB.
    • Place the foam and plastic plate cover back.
    • Line up the key switch pins with the sockets on the PCB before installing them.
    • Install the keyboard switches and apply a small amount of force to ensure they make contact with the PCB.
  10. Tofu65 Keyboard PCB Replacement: passo 10, imagem 1 %32 Tofu65 Keyboard PCB Replacement: passo 10, imagem 2 %32
    • Replace each keycaps onto the appropriate switch.
    • Press down firmly on each to ensure they are making contact.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Daniel Payan
Membro desde: 03/05/24
202 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 15
Últimos 30 dias: 68
Ao todo: 820
