Ir para o conteúdo principal
Toaster Oven Toasting Knob Replacement
O que você precisa
  1. Toaster Oven Toasting Knob Replacement, Toasting knob: passo 1, imagem 1 %32 Toaster Oven Toasting Knob Replacement, Toasting knob: passo 1, imagem 2 %32 Toaster Oven Toasting Knob Replacement, Toasting knob: passo 1, imagem 3 %32
    • Remove the two 4mm by 8mm screws from the back of the toaster oven.
  2. Toaster Oven Toasting Knob Replacement: passo 2, imagem 1 %32 Toaster Oven Toasting Knob Replacement: passo 2, imagem 2 %32 Toaster Oven Toasting Knob Replacement: passo 2, imagem 3 %32
    • Remove the four 4mm by 8mm screws from the black supports from the base of the toaster oven.
    • Take the two supports off of the bottom.
  3. Toaster Oven Toasting Knob Replacement: passo 3, imagem 1 %32 Toaster Oven Toasting Knob Replacement: passo 3, imagem 2 %32
    • Remove the two 4mm by 4mm screws from the base in order to remove the tray.
  4. Toaster Oven Toasting Knob Replacement: passo 4, imagem 1 %32
    • Slide the back panel off of the oven.
  5. Toaster Oven Toasting Knob Replacement: passo 5, imagem 1 %32
    • Grip the sides of the metal cover and lift the cover up off the toaster oven top.
  6. Toaster Oven Toasting Knob Replacement: passo 6, imagem 1 %32 Toaster Oven Toasting Knob Replacement: passo 6, imagem 2 %32 Toaster Oven Toasting Knob Replacement: passo 6, imagem 3 %32
    • The knob is missing in the first picture.
    • Push the knob into the hole.
    • The knob is now back in place in the last picture.
Conclusão
Alissa Mell
Membro desde: 09/26/17
101 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 25
Duração total: 1,860
