Introdução
Use this guide to replace the regulator assembly in your Titan Elite 3000 High Pressure Airless Sprayer.
O que você precisa
Turn off and unplug the sprayer.
Lay the sprayer down horizontally before continuing.
Use a pick tool to scrape the red paint from the side of the pressure control knob.
Use a flathead screwdriver to pry and remove the clip securing the stop sleeve.
Use an adjustable wrench to remove the regulator assembly.
4 outras pessoas executaram este guia.
