Introdução
Use this guide to replace the seal assembly on your RX-80 spray gun.
For more safety information, refer to the Operating Manual.
O que você precisa
Use an adjustable wrench to loosen the rear housing on the back of the spray gun.
Pull the rear housing straight off the spray gun to remove it.
Use a 3/8 inch socket to loosen the lock nut from the back of the spray gun.
Pull the lock nut straight off the spray gun to remove it.
Pull the seal assembly through the front of the spray gun to remove it.
Uma outra pessoa concluiu este guia.
