Introdução
Use this guide to replace the packings in your Titan Impact 410 Airless Sprayer.
The Home Depot recommends you also perform a bypass valve replacement when replacing the piston and packings.
Note: To access the piston, you must first remove the outlet valve. It's highly recommended that you service this valve with the parts included in the repacking kit (#704-586) before reassembling.
Note: Be sure to have an oversized crescent wrench before beginning your repair.
Some photos in this guide may contain slight visual discrepancies, but they won't affect the guide procedure.
O que você precisa
Use a Phillips driver to remove the four 15 mm-long screws securing the front cover.
Plug in the power cord.
Pulse the on/off switch until the pump stops at the bottom of its stroke.
Turn the sprayer off and unplug its power cord before continuing.
Pinch the return hose clamp and slide it downward to expose the connector.
Use an adjustable wrench to loosen and remove the foot valve housing.
Lay the sprayer down horizontally on its black metal bars before continuing.
Use an adjustable wrench to loosen the inlet valve housing from the pump block.
Teflon O-ring
Inlet valve seat
Inlet valve ball
Inlet valve washer
Nylon washer
Piston bushing
Use a 5/16 inch hex key to loosen and remove the outlet valve retainer.
Use a 3/8 inch hex key to loosen and remove the two screws securing the pump block.
Use your palm to push the piston through the pump block.
Remove the piston.
Use an adjustable wrench to loosen and remove the retainer nut.
Use a punch tool and a hammer to remove the upper packing assembly.
Repeat the same procedure for the lower packing assembly.
