Ir para o conteúdo principal
Titan Airless Sprayer IMPACT 410 Capacitor Replacement
O que você precisa
  1. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Safety precautions: passo 1, imagem 1 %32 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Safety precautions: passo 1, imagem 2 %32
    • Before you begin, make sure to follow the pressure relief procedure documented in the user manual before powering down the paint sprayer and disconnecting the pump.
    • Turn off and unplug the sprayer.
  2. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Unfasten the motor cover: passo 2, imagem 1 %32 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Unfasten the motor cover: passo 2, imagem 2 %32
    • Use a Phillips driver to remove the four 12 mm-long screws (two on either side) securing the motor cover.
  3. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the motor cover: passo 3, imagem 1 %32 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the motor cover: passo 3, imagem 2 %32 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the motor cover: passo 3, imagem 3 %32
    • Pull the motor cover straight off the motor.
  4. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor wires: passo 4, imagem 1 %32 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor wires: passo 4, imagem 2 %32 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor wires: passo 4, imagem 3 %32
    • Use diagonal cutters, or scissors, to cut the two cable ties bundling the capacitor's positive and negative wires.
    • During reassembly, replace the cable ties.
  5. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the negative wire: passo 5, imagem 1 %32 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the negative wire: passo 5, imagem 2 %32
    • Disconnect the black negative wire's spade connector.
    • Always grip cables by their connectors and not the wires themselves.
  6. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the positive wire: passo 6, imagem 1 %32 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the positive wire: passo 6, imagem 2 %32
    • Disconnect the red positive wire's bullet connector.
  7. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor: passo 7, imagem 1 %32 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor: passo 7, imagem 2 %32 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor: passo 7, imagem 3 %32
    • Grip the cable tie and slide it off the capacitors.
  8. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Discharge the capacitors: passo 8, imagem 1 %32
    • If you have already discharged the capacitors, skip this step.
    • Follow this guide to discharge your capacitors.
  9. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the capacitors: passo 9, imagem 1 %32 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the capacitors: passo 9, imagem 2 %32
    • The capacitors are lightly adhered to the motor body.
    • Insert a flathead screwdriver underneath the capacitors, between the bottom cell and the adhesive.
    • Pry up to separate the bottom cell from the motor body.
  10. Titan Airless Sprayer IMPACT 410 Capacitor Replacement: passo 10, imagem 1 %32 Titan Airless Sprayer IMPACT 410 Capacitor Replacement: passo 10, imagem 2 %32 Titan Airless Sprayer IMPACT 410 Capacitor Replacement: passo 10, imagem 3 %32
    • Insert a flathead screwdriver underneath the capacitors, between the top cell and the adhesive.
    • Pry up to separate the rest of the capacitor from the motor body.
    • Remove the capacitor.
    • During reassembly, if the adhesive is no longer sticky, replace it with double-sided foam adhesive.
Conclusão
Uma outra pessoa concluiu este guia.
Alex Diaz-Kokaisl
Membro desde: 01/16/22
161.945 Reputação
Autoria de 769 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 118
Autoria de 19.410 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 11
Duração total: 411
