Ir para o conteúdo principal
Tineco FLOOR ONE S3 Breeze Wheels Replacement
O que você precisa
  1. Tineco FLOOR ONE S3 Breeze Wheels Replacement, Brush Roller: passo 1, imagem 1 %32 Tineco FLOOR ONE S3 Breeze Wheels Replacement, Brush Roller: passo 1, imagem 2 %32
    • Place a finger on the lever located on the brush roller cover.
    • Firmly push the lever with a finger to remove the brush roller cover.
  2. Tineco FLOOR ONE S3 Breeze Wheels Replacement: passo 2, imagem 1 %32
    • Grasp the brush roller on its side.
    • Pull the brush roller out of its initial position.
  3. Tineco FLOOR ONE S3 Breeze Wheels Replacement, Wheels: passo 3, imagem 1 %32 Tineco FLOOR ONE S3 Breeze Wheels Replacement, Wheels: passo 3, imagem 2 %32
    • Remove four 10.6 mm screws from the plastic cover with a Phillips #1 screwdriver.
    • Remove the first plastic cover.
  4. Tineco FLOOR ONE S3 Breeze Wheels Replacement: passo 4, imagem 1 %32 Tineco FLOOR ONE S3 Breeze Wheels Replacement: passo 4, imagem 2 %32
    • Remove twelve 10.6 mm screws from the second plastic cover with a Phillips #1 screwdriver.
    • Remove the second plastic cover.
  5. Tineco FLOOR ONE S3 Breeze Wheels Replacement: passo 5, imagem 1 %32 Tineco FLOOR ONE S3 Breeze Wheels Replacement: passo 5, imagem 2 %32
    • Remove two 10.6 mm screws holding the wheels in place with a Phillips #1 screwdriver.
    • Remove the wheels.
    • The wheels do not need to be removed to access the motor.
Conclusão
Luke Guess
Membro desde: 02/14/24
193 Reputação
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 5
Últimos 30 dias: 13
Duração total: 55
