Ir para o conteúdo principal
Timbuk2 Pannier Whole Clip Bracket Replacement
O que você precisa
  1. Timbuk2 Pannier Whole Clip Bracket Replacement, Whole Clip Bracket: passo 1, imagem 1 %32
    • Here are the tools you will need:
    • Standard Screwdriver
    • New Pannier Whole Clip Bracket
    • Wrench
  2. Timbuk2 Pannier Whole Clip Bracket Replacement: passo 2, imagem 1 %32
    • To remove clip bracket, first remove all 3 clips using the #2 screwdriver or hand drill (Make sure to put clips and their screws and anchor plates in a safe place as to not misplace any such as a Ziploc bag).
  3. Timbuk2 Pannier Whole Clip Bracket Replacement: passo 3, imagem 1 %32
    • Unscrew all 13 small black screws. To do so, undo velcro flap located at the top of the laptop sleeve. With the wrench, hold nut in place in the back of the pannier.
  4. Timbuk2 Pannier Whole Clip Bracket Replacement: passo 4, imagem 1 %32
    • While holding nuts with the wrench, use the screwdriver to unscrew the screw in the front bracket.
  5. Timbuk2 Pannier Whole Clip Bracket Replacement: passo 5, imagem 1 %32 Timbuk2 Pannier Whole Clip Bracket Replacement: passo 5, imagem 2 %32
    • Remove old clip. Take new clip bracket and unscrew and remove middle clip.
  6. Timbuk2 Pannier Whole Clip Bracket Replacement: passo 6, imagem 1 %32
    • Replace the middle clip and screw it into place on the bag. Place the new clip bracket in place and screw in all 13 screws again.
    • As in step 3 and 4, hold nut with wrench while screwing clip in place. (Be sure to keep washers in between the screws and the body of the bag)
  7. Timbuk2 Pannier Whole Clip Bracket Replacement: passo 7, imagem 1 %32
    • You're done!
Linha de Chegada
Emilee
Membro desde: 03/13/14
1.591 Reputação
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,266
