Ir para o conteúdo principal
Timbuk2 Messenger Bag Male Cambuckle Replacement
O que você precisa
  1. Timbuk2 Messenger Bag Male Cambuckle Replacement, Male Cambuckle: passo 1, imagem 1 %32 Timbuk2 Messenger Bag Male Cambuckle Replacement, Male Cambuckle: passo 1, imagem 2 %32 Timbuk2 Messenger Bag Male Cambuckle Replacement, Male Cambuckle: passo 1, imagem 3 %32
  2. Timbuk2 Messenger Bag Male Cambuckle Replacement: passo 2, imagem 1 %32 Timbuk2 Messenger Bag Male Cambuckle Replacement: passo 2, imagem 2 %32 Timbuk2 Messenger Bag Male Cambuckle Replacement: passo 2, imagem 3 %32
    • Remove broken cam buckle. Un-thread strap from bottom plastic loop and take strap off.
  3. Timbuk2 Messenger Bag Male Cambuckle Replacement: passo 3, imagem 1 %32 Timbuk2 Messenger Bag Male Cambuckle Replacement: passo 3, imagem 2 %32 Timbuk2 Messenger Bag Male Cambuckle Replacement: passo 3, imagem 3 %32
    • Thread strap into new cam buckle through the buckle's top opening. Pull strap through the bottom of the buckle, ensuring that the strap goes in FRONT of the connectors as shown.
    • Make sure the strap is not twisted or facing the wrong way when inserting the new cambuckle!
  4. Timbuk2 Messenger Bag Male Cambuckle Replacement: passo 4, imagem 1 %32
    • Snap buckle into female cam buckle and close the buckle.
  5. Timbuk2 Messenger Bag Male Cambuckle Replacement: passo 5, imagem 1 %32 Timbuk2 Messenger Bag Male Cambuckle Replacement: passo 5, imagem 2 %32
    • Thread strap through the bottom of the plastic loop (the loop where the strap was thread though before).
    • Next, thread end of strap through the top end of plastic loop and pull to desired length.
  6. Timbuk2 Messenger Bag Male Cambuckle Replacement: passo 6, imagem 1 %32
    • Congrats! You're all done!
Linha de Chegada
Uma outra pessoa concluiu este guia.
Emilee
Membro desde: 03/13/14
1.621 Reputação
Autoria de 9 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 38
Ao todo: 4,304
