Ir para o conteúdo principal
TiVo Series 2 TCD540080 Power Supply Replacement
O que você precisa
  1. TiVo Series 2 TCD540080 Power Supply Replacement, Removal of TiVo Series 2 TCD540080 Case: passo 1, imagem 1 %32
    • Power down the TiVo and detach the power cable from the rear of the unit.
    • Wait 5 minutes for the unit to fully discharge before proceeding to the next step.
  2. TiVo Series 2 TCD540080 Power Supply Replacement: passo 2, imagem 1 %32
    • Remove the five T10 screws from the rear of the case using the Torx screwdriver.
  3. TiVo Series 2 TCD540080 Power Supply Replacement: passo 3, imagem 1 %32 TiVo Series 2 TCD540080 Power Supply Replacement: passo 3, imagem 2 %32
    • Lift up and pull back the outer casing towards the rear of the unit.
  4. TiVo Series 2 TCD540080 Power Supply Replacement, Power Supply: passo 4, imagem 1 %32 TiVo Series 2 TCD540080 Power Supply Replacement, Power Supply: passo 4, imagem 2 %32
    • Carefully remove the ribbon cable from the power supply. Hold the ribbon on both sides and pull up.
  5. TiVo Series 2 TCD540080 Power Supply Replacement: passo 5, imagem 1 %32
    • Disconnect the hard drive power cable. Firmly grip the white power connector and pull away from the hard drive.
    • Do not pull on the power cables when disconnecting power connector.
  6. TiVo Series 2 TCD540080 Power Supply Replacement: passo 6, imagem 1 %32
    • Rotate the device 180 degrees and remove the two T10 screws from the power supply board.
  7. TiVo Series 2 TCD540080 Power Supply Replacement: passo 7, imagem 1 %32 TiVo Series 2 TCD540080 Power Supply Replacement: passo 7, imagem 2 %32
    • Remove the four plastic standoffs.
    • Use pliers to squeeze the plastic pieces on the head together. Carefully press down on the standoff and pull up on the power supply.
  8. TiVo Series 2 TCD540080 Power Supply Replacement: passo 8, imagem 1 %32 TiVo Series 2 TCD540080 Power Supply Replacement: passo 8, imagem 2 %32
    • Lift the power supply out of the unit.
    • Do not touch any circuit elements or capacitors on the power supply, as they may hold a charge after the unit has been shut off.
Conclusão
Equipe
Cal Poly, Team 33-79, Johann Spring 2010 Membro de Cal Poly, Team 33-79, Johann Spring 2010
CPSU-JOHANN-S10S33G79
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 5,160
