Ir para o conteúdo principal
TiVo Series 2 TCD540080 Motherboard Replacement
O que você precisa
  1. TiVo Series 2 TCD540080 Motherboard Replacement, Removal of TiVo Series 2 TCD540080 Case: passo 1, imagem 1 %32
    • Power down the TiVo and detach the power cable from the rear of the unit.
    • Wait 5 minutes for the unit to fully discharge before proceeding to the next step.
  2. TiVo Series 2 TCD540080 Motherboard Replacement: passo 2, imagem 1 %32
    • Remove the five T10 screws from the rear of the case using the Torx screwdriver.
  3. TiVo Series 2 TCD540080 Motherboard Replacement: passo 3, imagem 1 %32 TiVo Series 2 TCD540080 Motherboard Replacement: passo 3, imagem 2 %32
    • Lift up and pull back the outer casing towards the rear of the unit.
  4. TiVo Series 2 TCD540080 Motherboard Replacement, Motherboard: passo 4, imagem 1 %32
    • On the rear of the device, remove the right screw with a T10 Torx Screwdriver.
    • Unscrew the two black screws on the left with a T8 Torx Screwdriver.
  5. TiVo Series 2 TCD540080 Motherboard Replacement: passo 5, imagem 1 %32
    • Disconnect the white ribbon cable from the motherboard.
    • The black base where the cable is connected is not part of the cable. Do not lift up on it!
  6. TiVo Series 2 TCD540080 Motherboard Replacement: passo 6, imagem 1 %32
    • Remove fan power connector.
  7. TiVo Series 2 TCD540080 Motherboard Replacement: passo 7, imagem 1 %32
    • Disconnect the hard drive data cable.
    • Use extreme caution when unplugging the connector and do not disconnect the data cable by pulling on the cable itself.
  8. TiVo Series 2 TCD540080 Motherboard Replacement: passo 8, imagem 1 %32
    • Disconnect the connector cable that goes to the lights on the front of the device.
  9. TiVo Series 2 TCD540080 Motherboard Replacement: passo 9, imagem 1 %32
    • Unscrew the four screws on the motherboard with a T10 screwdriver.
  10. TiVo Series 2 TCD540080 Motherboard Replacement: passo 10, imagem 1 %32 TiVo Series 2 TCD540080 Motherboard Replacement: passo 10, imagem 2 %32 TiVo Series 2 TCD540080 Motherboard Replacement: passo 10, imagem 3 %32
    • Use a pair of needle-nose pliers to make the two tabs parallel with the open slots.
    • It is recommended that you do not bend these back after putting unit back together as they may break after repeated use.
  11. TiVo Series 2 TCD540080 Motherboard Replacement: passo 11, imagem 1 %32
    • Pull the motherboard out towards the front of the TiVo unit, then pull up to remove it.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 33-79, Johann Spring 2010 Membro de Cal Poly, Team 33-79, Johann Spring 2010
CPSU-JOHANN-S10S33G79
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 17
Duração total: 4,430
