Ir para o conteúdo principal
TiVo Series 2 TCD540080 Cooling Fan Replacement
O que você precisa
  1. TiVo Series 2 TCD540080 Cooling Fan Replacement, Removal of TiVo Series 2 TCD540080 Case: passo 1, imagem 1 %32
    • Power down the TiVo and detach the power cable from the rear of the unit.
    • Wait 5 minutes for the unit to fully discharge before proceeding to the next step.
  2. TiVo Series 2 TCD540080 Cooling Fan Replacement: passo 2, imagem 1 %32
    • Remove the five T10 screws from the rear of the case using the Torx screwdriver.
  3. TiVo Series 2 TCD540080 Cooling Fan Replacement: passo 3, imagem 1 %32 TiVo Series 2 TCD540080 Cooling Fan Replacement: passo 3, imagem 2 %32
    • Lift up and pull back the outer casing towards the rear of the unit.
  4. TiVo Series 2 TCD540080 Cooling Fan Replacement, Cooling Fan: passo 4, imagem 1 %32
    • The fan is held in by four T15 screws on the rear of the device.
  5. TiVo Series 2 TCD540080 Cooling Fan Replacement: passo 5, imagem 1 %32 TiVo Series 2 TCD540080 Cooling Fan Replacement: passo 5, imagem 2 %32
    • Take the wound red and black wires coming from the fan and follow them back to the logic board.
    • Unplug the connector from the motherboard.
  6. TiVo Series 2 TCD540080 Cooling Fan Replacement: passo 6, imagem 1 %32 TiVo Series 2 TCD540080 Cooling Fan Replacement: passo 6, imagem 2 %32
    • Pull the fan towards the front and out of the TiVo unit.
Conclusão
Equipe
Cal Poly, Team 33-79, Johann Spring 2010 Membro de Cal Poly, Team 33-79, Johann Spring 2010
CPSU-JOHANN-S10S33G79
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 12
Duração total: 5,249
