Ir para o conteúdo principal
TiVo Series 2 TCD24008A Motherboard Replacement
O que você precisa
  1. TiVo Series 2 TCD24008A Motherboard Replacement, Cover: passo 1, imagem 1 %32
    • Unscrew the five 0.31 inch T-9 screws on the back cover.
  2. TiVo Series 2 TCD24008A Motherboard Replacement: passo 2, imagem 1 %32
    • Slide the cover towards the back until it is no longer under the front cover.
  3. TiVo Series 2 TCD24008A Motherboard Replacement: passo 3, imagem 1 %32
    • Lift the cover up and off the device.
  4. TiVo Series 2 TCD24008A Motherboard Replacement, Motherboard: passo 4, imagem 1 %32
    • Unscrew the 0.31 inch T-9 size screw on the back panel
    • Unscrew the two 0.59 inch T-8 size screws on the back panel
  5. TiVo Series 2 TCD24008A Motherboard Replacement: passo 5, imagem 1 %32
    • Unplug the fan from the motherboard by gently pulling up on the red plug.
  6. TiVo Series 2 TCD24008A Motherboard Replacement: passo 6, imagem 1 %32
    • Unplug the ribbon attaching the front panel sensor by pulling it upwards gently.
  7. TiVo Series 2 TCD24008A Motherboard Replacement: passo 7, imagem 1 %32
    • Unplug the ribbon connecting the hard drive to the motherboard by pulling straight up on the ribbon. This may require some gentle wiggling.
  8. TiVo Series 2 TCD24008A Motherboard Replacement: passo 8, imagem 1 %32
    • Unplug the ribbon connecting the power supply to the motherboard by pulling upwards on this ribbon.
  9. TiVo Series 2 TCD24008A Motherboard Replacement: passo 9, imagem 1 %32 TiVo Series 2 TCD24008A Motherboard Replacement: passo 9, imagem 2 %32
    • Locate the four metal tabs on the motherboard.
    • Using Pliers, bend each of the tabs until they align straight with the holes underneath them.
    • Bend these just enough to slip them through the holes. Over-bending could snap these tabs. While this won't affect how the TiVo functions, they are there to secure the motherboard to prevent damage.
  10. TiVo Series 2 TCD24008A Motherboard Replacement: passo 10, imagem 1 %32
    • Locate and remove the four 0.31 inch T-9 size screws at the front of the motherboard.
  11. TiVo Series 2 TCD24008A Motherboard Replacement: passo 11, imagem 1 %32 TiVo Series 2 TCD24008A Motherboard Replacement: passo 11, imagem 2 %32
    • Pull directly up on the motherboard so that it slips over the four golden metal tabs.
    • Pull up and away from the back panel so all of the cable inputs slip through the casing.
Conclusão
Cody Hunter
Membro desde: 10/10/11
22 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 5-33, Amido Fall 2011 Membro de Cal Poly, Team 5-33, Amido Fall 2011
CPSU-AMIDO-F11S5G33
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,078
