Introdução
This guide will show you how to replace the connection port for the pedals.
O que você precisa
Using a small plastic opening tool, gently pry up the white connector that connects the pedals to the board.
By pulling up on both ends of the port you will be able to pull out the port to remove it.
2 comentários
I just need to know where to get a replacement USB cable from ( the USB to the circular end part).
I need to know what USB cable connects the round cable end on the steerwheel to the Xbox one
