Ir para o conteúdo principal
Thustmaster Ferrari 458 Spider Racing Wheel Bottom Cover Replacement
O que você precisa
  1. Thustmaster Ferrari 458 Spider Racing Wheel Bottom Cover Replacement, Bottom Cover: passo 1, imagem 1 %32
    • Remove the black 10mm using a JIS #1 screw driver.
    • There are 12 screws.
    • Two of the screws are deep inside the device you might need to use a slim screwdriver.
    • In the picture you see a plastic opening tool instead of screw driver because we did not have our screw driver when we were taking the picture.
  2. Thustmaster Ferrari 458 Spider Racing Wheel Bottom Cover Replacement: passo 2, imagem 1 %32 Thustmaster Ferrari 458 Spider Racing Wheel Bottom Cover Replacement: passo 2, imagem 2 %32
    • Remove the two 10mm black screws on the top of device using a Hex 2.5mm Key. Only the two outside screws.
    • Gently pull apart both halves of device to access inside.
Conclusão
Mohammed Alsogair
Membro desde: 10/18/17
339 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S1-G33, Cagle Fall 2017 Membro de USF Tampa, Team S1-G33, Cagle Fall 2017
USFT-CAGLE-F17S1G33
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 18
Duração total: 5,456
