Ir para o conteúdo principal
Thrustmaster T3PM Maintenance
O que você precisa
  1. Thrustmaster T3PM Maintenance, Disconnect the pedal heads: passo 1, imagem 1 %32 Thrustmaster T3PM Maintenance, Disconnect the pedal heads: passo 1, imagem 2 %32
    • Unscrew all 6 screws from the pedal heads
    • Note the positioning of the pedal heads or take this opportunity to try out new position
    • Before starting, unplug your T3PM.
    Pergunte ao FixBot
  2. Thrustmaster T3PM Maintenance, Remove screws from the bottom: passo 2, imagem 1 %32
    • Using Phillips screwdriver remove all screws at the bottom.
    Pergunte ao FixBot
  3. Thrustmaster T3PM Maintenance, Remove the top cover: passo 3, imagem 1 %32
    • Remove the top cover and put it aside
    Pergunte ao FixBot
    • Clean off any dust, residue, pet hair and other foreign debris that has accumulated inside the pedal set.
    Pergunte ao FixBot
  4. Thrustmaster T3PM Maintenance, Inspect the wires and tape.: passo 5, imagem 1 %32 Thrustmaster T3PM Maintenance, Inspect the wires and tape.: passo 5, imagem 2 %32
    • Make sure that the wires and the main cable are secure.
    • Replace sticky tape if necessary.
    Pergunte ao FixBot
  5. Thrustmaster T3PM Maintenance, Thoroughly clean each pedal.: passo 6, imagem 1 %32
    • Clean off any dust, residue, pet hair etc from the pedals themselves, near the sensors and springs.
    • Make sure to clean off the extremities of the pedals.
    Pergunte ao FixBot
  6. Thrustmaster T3PM Maintenance, Clean the sensors: passo 7, imagem 1 %32 Thrustmaster T3PM Maintenance, Clean the sensors: passo 7, imagem 2 %32
    • Using an air-blower, compressed air-can or other tool, clean the sensors.
    • Be cautions as to not damage the sensors, wires or the connectors.
    • Watch out for Electro-static Discharge. Make sure not to touch the sensors or use anti-static wrist strap.
    Pergunte ao FixBot
  7. Thrustmaster T3PM Maintenance, Inspect the springs.: passo 8, imagem 1 %32
    • Inspect the conditions of the gas and clutch springs.
    • Re-lubricate if necessary.
    Pergunte ao FixBot
Conclusão
To reassemble your device, follow the steps 1,2,3 in reverse order.
Formica Fusca
Membro desde: 08/01/24
2.600 Reputação
Autoria de 15 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 28
Últimos 30 dias: 100
Ao todo: 1,535
