Ir para o conteúdo principal
Thrustmaster T Flight Hotas 4 Trigger Replacement
O que você precisa
  1. Thrustmaster T Flight Hotas 4 Trigger Replacement, J1 Screws on Joystick Handle: passo 1, imagem 1 %32 Thrustmaster T Flight Hotas 4 Trigger Replacement, J1 Screws on Joystick Handle: passo 1, imagem 2 %32
    • Be sure to disconnect the controller from the power source before disassembling.
    • Remove the four 15 mm J1 JIS head screws from the exterior of the joystick.
  2. Thrustmaster T Flight Hotas 4 Trigger Replacement, Trigger: passo 2, imagem 1 %32 Thrustmaster T Flight Hotas 4 Trigger Replacement, Trigger: passo 2, imagem 2 %32 Thrustmaster T Flight Hotas 4 Trigger Replacement, Trigger: passo 2, imagem 3 %32
    • Carefully remove the paneling of the joystick using your hands to pull the panels apart.
    • Be aware that the panels will fall apart when the screws are removed unless they are held together.
    • This metal piece must be put back into its correct position. If not it will impair the movement of the joystick's rudder mechanism.
  3. Thrustmaster T Flight Hotas 4 Trigger Replacement: passo 3, imagem 1 %32
    • Remove the 8 mm J1 JIS head screw that is holding the trigger in place.
  4. Thrustmaster T Flight Hotas 4 Trigger Replacement: passo 4, imagem 1 %32 Thrustmaster T Flight Hotas 4 Trigger Replacement: passo 4, imagem 2 %32 Thrustmaster T Flight Hotas 4 Trigger Replacement: passo 4, imagem 3 %32
    • Remove trigger and metal spring.
    • Remember to position the metal spring in the exact same place.
Conclusão
Aaron Banaga
Membro desde: 09/11/17
526 Reputação
Autoria de 4 guias
Equipe
CSU Fullerton, Team S2-G1, Bruce Fall 2017 Membro de CSU Fullerton, Team S2-G1, Bruce Fall 2017
CSUF-BRUCE-F17S2G1
Membros da 3
Autoria de 13 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 3,372
