Ir para o conteúdo principal
Thrustmaster T Flight Hotas 4 Throttle Rudder Replacement
O que você precisa
  1. Thrustmaster T Flight Hotas 4 Throttle Rudder Replacement, J1 Screws on Throttle: passo 1, imagem 1 %32
    • Be sure to disconnect the controller from the power source before disassembling.
    • Remove the five 15 mm J1 JIS head screws from the front of the throttle.
  2. Thrustmaster T Flight Hotas 4 Throttle Rudder Replacement, Throttle Panel: passo 2, imagem 1 %32 Thrustmaster T Flight Hotas 4 Throttle Rudder Replacement, Throttle Panel: passo 2, imagem 2 %32
    • Using your hands, pull away the panel from the throttle.
  3. Thrustmaster T Flight Hotas 4 Throttle Rudder Replacement, Throttle Rudder: passo 3, imagem 1 %32 Thrustmaster T Flight Hotas 4 Throttle Rudder Replacement, Throttle Rudder: passo 3, imagem 2 %32
    • Remove the four 13 mm J1 JIS head screws from the rudder assembly holder.
  4. Thrustmaster T Flight Hotas 4 Throttle Rudder Replacement: passo 4, imagem 1 %32
    • Gently remove the panel that is covering the rudder.
  5. Thrustmaster T Flight Hotas 4 Throttle Rudder Replacement: passo 5, imagem 1 %32
    • Proceed to remove the rudder from the throttle.
Conclusão
Julissa Orozco
Membro desde: 09/20/17
351 Reputação
Autoria de 2 guias
Equipe
CSU Fullerton, Team S2-G1, Bruce Fall 2017 Membro de CSU Fullerton, Team S2-G1, Bruce Fall 2017
CSUF-BRUCE-F17S2G1
3 Membros
Autoria de 23 guias
1Comentário do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 20
Ao todo: 2,070
