Ir para o conteúdo principal
Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement
O que você precisa
  1. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement, J1 Screws on Throttle: passo 1, imagem 1 %32
    • Be sure to disconnect the controller from the power source before disassembling.
    • Remove the five 15 mm J1 JIS head screws from the front of the throttle.
  2. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement, Throttle Panel: passo 2, imagem 1 %32 Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement, Throttle Panel: passo 2, imagem 2 %32
    • Using your hands, pull away the panel from the throttle.
  3. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement, R2 & L2 Buttons: passo 3, imagem 1 %32 Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement, R2 & L2 Buttons: passo 3, imagem 2 %32
    • Remove the two 7 mm J1 JIS head screws from the panel covering the buttons.
  4. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: passo 4, imagem 1 %32 Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: passo 4, imagem 2 %32
    • Pull the panel that is covering the R2 button away from the throttle.
  5. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: passo 5, imagem 1 %32 Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: passo 5, imagem 2 %32
    • Carefully push the R2 button from the outside of the panel.
    • Be cautious of the spring attached to the button as it can be easily lost.
  6. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: passo 6, imagem 1 %32 Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: passo 6, imagem 2 %32
    • Remove the two 4 mm J1 JIS head screws from the panel covering the L2 button.
  7. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: passo 7, imagem 1 %32 Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: passo 7, imagem 2 %32
    • Carefully push the L2 button from the outside of the panel.
Conclusão
Crystal Nguyen
Membro desde: 09/11/17
624 Reputação
Autoria de 4 guias
Equipe
CSU Fullerton, Team S2-G1, Bruce Fall 2017 Membro de CSU Fullerton, Team S2-G1, Bruce Fall 2017
CSUF-BRUCE-F17S2G1
Membros da 3
Autoria de 13 guias
Um comentário
Hello, m R2 button is broken. Do you know where i can print a new one ?
louis_tiquet - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 13
Duração total: 1,293
