Ir para o conteúdo principal
Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement
O que você precisa
  1. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement, J1 Screws on Throttle: passo 1, imagem 1 %32
    • Be sure to disconnect the controller from the power source before disassembling.
    • Remove the five 15 mm J1 JIS head screws from the front of the throttle.
  2. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement, Throttle Panel: passo 2, imagem 1 %32 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement, Throttle Panel: passo 2, imagem 2 %32
    • Using your hands, pull away the panel from the throttle.
  3. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement, PlayStation Action Buttons: passo 3, imagem 1 %32 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement, PlayStation Action Buttons: passo 3, imagem 2 %32
    • Remove the two 8 mm J1 JIS head screws.
  4. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: passo 4, imagem 1 %32 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: passo 4, imagem 2 %32
    • Remove exterior panel from the throttle by using your hands to gently pull the panel away.
  5. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: passo 5, imagem 1 %32 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: passo 5, imagem 2 %32
    • Remove the two 6 mm J1 JIS head screws from the circuit board.
  6. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: passo 6, imagem 1 %32
    • Carefully remove the circuit board.
  7. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: passo 7, imagem 1 %32 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: passo 7, imagem 2 %32
    • Remove the 6 mm J1 JIS head screw that is attached to the black plastic cover.
  8. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: passo 8, imagem 1 %32 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: passo 8, imagem 2 %32
    • Remove black plastic cover.
  9. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: passo 9, imagem 1 %32 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: passo 9, imagem 2 %32
    • Once the black plastic cover is removed, push the buttons inward from the outside of the device.
    • Be aware of the springs. They are small and easy to lose.
    • This step only replaces the x, square, and circle buttons.
  10. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: passo 10, imagem 1 %32 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: passo 10, imagem 2 %32
    • Remove the two 6 mm J1 JIS head screws that are attached to the tan plastic cover.
    • Removal of the screws will detach the exterior panel from the device.
  11. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: passo 11, imagem 1 %32
    • Carefully remove tan plastic cover.
  12. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: passo 12, imagem 1 %32
    • Once the black panel is disconnected, push the triangle button inward from the outside of the exterior panel.
Conclusão
Aaron Banaga
Membro desde: 09/11/17
526 Reputação
Autoria de 4 guias
Equipe
CSU Fullerton, Team S2-G1, Bruce Fall 2017 Membro de CSU Fullerton, Team S2-G1, Bruce Fall 2017
CSUF-BRUCE-F17S2G1
Membros da 3
Autoria de 13 guias
Um comentário
Very well presented. Just one question - if one of these buttons (or rather the switch that it activates) has broken, how do you fix it? Where can you get a replacement part if that is what is needed?
Anthony Vallillo - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 14
Duração total: 1,571
