Ir para o conteúdo principal
Thrustmaster T Flight Hotas 4 J1 Screws on Joystick Handle Replacement
O que você precisa
  1. Thrustmaster T Flight Hotas 4 J1 Screws on Joystick Handle Replacement, J1 Screws on Joystick Handle: passo 1, imagem 1 %32 Thrustmaster T Flight Hotas 4 J1 Screws on Joystick Handle Replacement, J1 Screws on Joystick Handle: passo 1, imagem 2 %32
    • Be sure to disconnect the controller from the power source before disassembling.
    • Remove the four 15 mm J1 JIS head screws from the exterior of the joystick.
Conclusão
3 outras pessoas executaram este guia.
Aaron Banaga
Membro desde: 09/11/17
526 Reputação
Autoria de 4 guias
Equipe
CSU Fullerton, Team S2-G1, Bruce Fall 2017 Membro de CSU Fullerton, Team S2-G1, Bruce Fall 2017
CSUF-BRUCE-F17S2G1
Membros da 3
Autoria de 13 guias
4 comentários
there are small plastic pieces in mine, when i took it off now my joystick wont work or turn properly and I havent found any guide to where these pieces go??
beardy1 - Responder
I'm wondering the same thing right now. That round spring with the arms on it and the black lC shaped plastic piece.
Brent Taylor-Wooster -
On the bottom of the stick assembly you will see a small slot head screw like indent. That is a built in manual stop, rotate 45 to 90 degrees in the loosening direction, it will un lock
Edit: I was trying to include 3 pictures of the assembly and install but no luck sorry
Timothy Brake -
I found this link which shows where that black plastic piece goes: https://channellfd.com/t-flight-hotas-x-...
You know how there are three holes on the bottom of the stick, but only two screws? It goes in the third hole.
HolleringHuskarl -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 27
Duração total: 3,865
