Ir para o conteúdo principal
Three-way Switch Replacement
O que você precisa
    1. Three-way Switch Replacement, Three-way Switch: passo 1, imagem 1 %32 Three-way Switch Replacement, Three-way Switch: passo 1, imagem 2 %32
      • Locate and turn off the circuit breaker for your switch.
      • Try to turn the switch to ensure you turned the power off.
      Pergunte ao FixBot
      Comentar
    2. Three-way Switch Replacement: passo 2, imagem 1 %32
      • Use the screwdriver to remove the 15mm Flathead screws on the wall plate.
      • Remove the wall plate from the wall.
      Pergunte ao FixBot
      Comentar
    3. Three-way Switch Replacement, Determine voltage absence: passo 3, imagem 1 %32 Three-way Switch Replacement, Determine voltage absence: passo 3, imagem 2 %32
      • While wearing insulated gloves, gently pull out the switch and use a Duspol or any other Voltmeter to test if there is voltage at the contacts.
      • You can also use a single pole phase tester, but that's not the proper way to do it.
      • Do not work on live circuits if you are not an experienced professional.
      Pergunte ao FixBot
      Comentar
    4. Three-way Switch Replacement: passo 4, imagem 1 %32 Three-way Switch Replacement: passo 4, imagem 2 %32 Three-way Switch Replacement: passo 4, imagem 3 %32
      • Label the black live or load wire which connects to the power or the device and usually on the down position of the switch.
      • Use the screwdriver to loosen the 5mm Phillips #1 screw so that you can remove the live or load wire from the switch.
      Pergunte ao FixBot
      Comentar
    5. Three-way Switch Replacement: passo 5, imagem 1 %32 Three-way Switch Replacement: passo 5, imagem 2 %32
      • Label the two traveler wires where the up position is held by gold screws of the old switch.
      Pergunte ao FixBot
      Comentar
    6. Three-way Switch Replacement: passo 6, imagem 1 %32 Three-way Switch Replacement: passo 6, imagem 2 %32 Three-way Switch Replacement: passo 6, imagem 3 %32
      • Use the screwdriver to loosen the 5mm Phillips #1 screws so that you can remove these two traveler wires.
      • After the wires are removed, disconnect the old switch.
      Pergunte ao FixBot
      Comentar
    7. Three-way Switch Replacement: passo 7, imagem 1 %32 Three-way Switch Replacement: passo 7, imagem 2 %32
      • You will find there are one or two wires left in the outlet box.
      • Ground wire is the bare copper wire.
      • The white one is the neutral wire that may be in another outlet box.
      • Please label the neutral wire and the ground wire.
      Pergunte ao FixBot
      Comentar
    8. Three-way Switch Replacement: passo 8, imagem 1 %32 Three-way Switch Replacement: passo 8, imagem 2 %32 Three-way Switch Replacement: passo 8, imagem 3 %32
      • Using your new switch, link two traveler wires to the positions with gold screws of the new switch and tighten the 5mm Phillips #1 screws.
      • Link the live or load wire to the position with a black screw and tighten the 5mm Phillips #1 screw.
      • Please ensure you link the wires to the correct places.
      Pergunte ao FixBot
      Comentar
    9. Three-way Switch Replacement: passo 9, imagem 1 %32 Three-way Switch Replacement: passo 9, imagem 2 %32
      • If there is a green 5mm Phillips #1 screw on the new switch, please link the ground wire to and tighten it.
      • For the intelligent switch, there would be a green wire so that you can group the ground wire with the green wire and tighten them with a wire nut.
      Pergunte ao FixBot
      Comentar
    10. Three-way Switch Replacement: passo 10, imagem 1 %32 Three-way Switch Replacement: passo 10, imagem 2 %32
      • There is an extra white wire on the intelligent switch.
      • Group the neutral wire with the white wire and use the wire nut to tighten them.
      Pergunte ao FixBot
      Comentar
    11. Three-way Switch Replacement: passo 11, imagem 1 %32 Three-way Switch Replacement: passo 11, imagem 2 %32 Three-way Switch Replacement: passo 11, imagem 3 %32
      • Turn the power on and check whether the new switch works.
      • Gently push the wires back into the outlet box.
      • You’ll also need to leave some space for the switch.
      • Secure the new switch with the 10mm Phillips #1 screws.
      • Finally, secure the wall plate.
      Pergunte ao FixBot
      Comentar
Conclusão
Tao Zhuo
Membro desde: 01/19/21
256 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 40
Últimos 30 dias: 129
Ao todo: 3,190
