Ir para o conteúdo principal
ThinkPad Yoga 12 SSD Replacement
O que você precisa
  1. ThinkPad Yoga 12 SSD Replacement, Screws: passo 1, imagem 1 %32 ThinkPad Yoga 12 SSD Replacement, Screws: passo 1, imagem 2 %32 ThinkPad Yoga 12 SSD Replacement, Screws: passo 1, imagem 3 %32
    • Remove the ten Phillips screws using a Philips 00 screwdriver
  2. ThinkPad Yoga 12 SSD Replacement, Prying: passo 2, imagem 1 %32 ThinkPad Yoga 12 SSD Replacement, Prying: passo 2, imagem 2 %32
    • Pry up the case carefully using a spudger.
    • Make sure to not push the spudger in too far, as this could result in internal damage
  3. ThinkPad Yoga 12 SSD Replacement, Lift off cover: passo 3, imagem 1 %32
    • Lift off the cover, and you're done!
  4. ThinkPad Yoga 12 SSD Replacement, Remove SSD from the laptop: passo 4, imagem 1 %32 ThinkPad Yoga 12 SSD Replacement, Remove SSD from the laptop: passo 4, imagem 2 %32
    • Carefully remove two Phillips screws with a Phillips 0 screwdriver
    • Static sensitive components!
  5. ThinkPad Yoga 12 SSD Replacement: passo 5, imagem 1 %32 ThinkPad Yoga 12 SSD Replacement: passo 5, imagem 2 %32
    • Gently grab the plastic tab. Lift and pull the SSD assembly out of the computer
  6. ThinkPad Yoga 12 SSD Replacement, Remove enclosure: passo 6, imagem 1 %32 ThinkPad Yoga 12 SSD Replacement, Remove enclosure: passo 6, imagem 2 %32
    • Remove the 4 identical Phillips screws with a Phillips 00 screw driver (they are on both sides).
  7. ThinkPad Yoga 12 SSD Replacement, Done!: passo 7, imagem 1 %32 ThinkPad Yoga 12 SSD Replacement, Done!: passo 7, imagem 2 %32
    • Carefully remove the SSD enclosure.
    • Note: The SSD enclosure is made of thin metal. It can be easily deformed. Be careful when removing from the SSD.
Conclusão
6 outras pessoas executaram este guia.
[deleted]
Membro desde: 03/18/18
1.324 Reputação
Autoria de 3 guias
Um comentário
Almost perfect instructions. I do recommend removing the active pen first. Also it's a good idea to remind people that the active pen holder is screwed to the case cover from the inside and will come out as part of the cover.
Dani Deitch - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 24
Duração total: 4,924
