Ir para o conteúdo principal
ThinkPad Yoga 12 Battery Replacement
O que você precisa
  1. ThinkPad Yoga 12 Battery Replacement, Screws: passo 1, imagem 1 %32 ThinkPad Yoga 12 Battery Replacement, Screws: passo 1, imagem 2 %32 ThinkPad Yoga 12 Battery Replacement, Screws: passo 1, imagem 3 %32
    • Remove the ten Phillips screws using a Philips 00 screwdriver
    Ten screws, but who’s counting. Thank you!
    jthrall - Responder
  2. ThinkPad Yoga 12 Battery Replacement, Prying: passo 2, imagem 1 %32 ThinkPad Yoga 12 Battery Replacement, Prying: passo 2, imagem 2 %32
    • Pry up the case carefully using a spudger.
    • Make sure to not push the spudger in too far, as this could result in internal damage
  3. ThinkPad Yoga 12 Battery Replacement, Lift off cover: passo 3, imagem 1 %32
    • Lift off the cover, and you're done!
  4. ThinkPad Yoga 12 Battery Replacement, Removing the screw: passo 4, imagem 1 %32 ThinkPad Yoga 12 Battery Replacement, Removing the screw: passo 4, imagem 2 %32
    • Remove the one and only Phillips screw with a Phillips 0 screwdriver.
  5. ThinkPad Yoga 12 Battery Replacement, Lift: passo 5, imagem 1 %32 ThinkPad Yoga 12 Battery Replacement, Lift: passo 5, imagem 2 %32
    • Carefully lift the battery. There is a small bit of adhesive underneath the green.
    • Make sure to not bend the battery! This can result in a violent explosion with flames and shrapnel!
  6. ThinkPad Yoga 12 Battery Replacement, Connecter: passo 6, imagem 1 %32 ThinkPad Yoga 12 Battery Replacement, Connecter: passo 6, imagem 2 %32 ThinkPad Yoga 12 Battery Replacement, Connecter: passo 6, imagem 3 %32
    • Carefully pull the connector out from underneath the logic board to remove the battery.
Conclusão
9 outras pessoas executaram este guia.
[deleted]
Membro desde: 03/18/18
1.324 Reputação
Autoria de 3 guias
Um comentário
These directions (and those for replacing the SSD) were very helpful. Everything worked well for about a week after which time the battery started having charging problems (again). The computer will start to charge, get to ~25% at which point the machine reports that it’s charging, but doesn’t get beyond ~25%. “Troubleshooting” in Win 10 doesn’t reveal any troubles to shoot. I am now trying to figure out whether the problem is with the new (supposedly Lenovo-brand) battery or perhaps the power cord. Any suggestions?
ellamama - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 28
Duração total: 6,515
