Introdução
In this guide, you will learn how to open the ThinkPad X1 Carbon and replace the wireless card.
O que você precisa
Using the #0 Phillips screwdriver, loosen the seven cover screws. they will not come all of the way out.
Slide battery connector in the direction if the arrow to disconnect.
Carefully remove the antenna cables and slide out the card in the direction of the arrow.
3 outras pessoas executaram este guia.
