Ir para o conteúdo principal
ThinkPad X1 Carbon SSD Replacement
O que você precisa
  1. ThinkPad X1 Carbon SSD Replacement, Remove Bottom Cover: passo 1, imagem 1 %32
    • Use phillips #2 screwdriver to loosen seven cover screws.
  2. ThinkPad X1 Carbon SSD Replacement, Remove Bottom Cover: passo 2, imagem 1 %32
    • Use spudger to pop open bottom cover, remove and set aside.
  3. ThinkPad X1 Carbon SSD Replacement, Disconnect Battery: passo 3, imagem 1 %32
    • Disconnect the battery connector from the main board by pulling the connector towards the battery.
  4. ThinkPad X1 Carbon SSD Replacement, Remove SSD Screw: passo 4, imagem 1 %32
    • Use the # 2 phillips screwdriver and remove the screw holding the SSD in place.
  5. ThinkPad X1 Carbon SSD Replacement, Remove SSD: passo 5, imagem 1 %32
    • Remove the SSD by sliding it out of the connector to the right.
Conclusão
12 outras pessoas executaram este guia.
Mike
Membro desde: 06/23/16
1.954 Reputação
Autoria de 5 guias
Equipe
iReconstruction Membro de iReconstruction
Business
1 Membro
Autoria de 17 guias
8Comentários do guia
hi, can advise me which of the latest ssd 256/500 GB ssd's would work on a x1 carbon i5?
hardtail1969 - Responder
Really need to put the version/generation of the x1 carbon.. The gen 1 does not look like this inside and I’m spending way too much time trying to figure out what SSD it will take
Eric Metzger - Responder
Even for new models still can be used. same m.2 drive that might be located in the middle or top right of the device. Once the screws are off it is a very easy process.
jwalker8931 - Responder
I just replaced the SSD on my gen 6 and the steps are so easy: undo 5 screws, open up, undo 1 screw to loosen the M.2 module, replace and put things back together. There is no need to mess around with the battery connection at all.
haivu - Responder
A proper way, yes you need to disconnect the battery. You will learn it a hard way just a minor mistake, will blow your Mother Board and you will remember to disconnect them next time. The instruction is great.
Ryan Chau -
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 85
Últimos 30 dias: 461
Ao todo: 52,393
