Ir para o conteúdo principal
ThinkPad X1 Carbon Push Button Controls Replacement
O que você precisa
  1. ThinkPad X1 Carbon Push Button Controls Replacement, Push Button Controls: passo 1, imagem 1 %32
    • Unscrew the seven screws located on the back of the device.
  2. ThinkPad X1 Carbon Push Button Controls Replacement: passo 2, imagem 1 %32
    • Slide the plastic the spudger along the edge of the device to separate the keyboard tray.
  3. ThinkPad X1 Carbon Push Button Controls Replacement: passo 3, imagem 1 %32
    • Flip the device over and open it to lift the keyboard tray from the body of the device.
  4. ThinkPad X1 Carbon Push Button Controls Replacement: passo 4, imagem 1 %32
    • Use the Plastic Spudger to gently release the ribbon cable attached to the keyboard.
    • Place device to side.
  5. ThinkPad X1 Carbon Push Button Controls Replacement: passo 5, imagem 1 %32 ThinkPad X1 Carbon Push Button Controls Replacement: passo 5, imagem 2 %32 ThinkPad X1 Carbon Push Button Controls Replacement: passo 5, imagem 3 %32
    • Unlock and remove the 3 ribbon cables along the top of the keyboard tray.
  6. ThinkPad X1 Carbon Push Button Controls Replacement: passo 6, imagem 1 %32
    • Locate and unscrew the 3 silver screws.
  7. ThinkPad X1 Carbon Push Button Controls Replacement: passo 7, imagem 1 %32
    • Gently wiggle and lift the Push Button board from the keyboard tray.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 27
Ao todo: 1,866
