Ir para o conteúdo principal
ThinkPad X1 Carbon Fingerprint Reader Replacement
O que você precisa
  1. ThinkPad X1 Carbon Fingerprint Reader Replacement, Fingerprint Reader: passo 1, imagem 1 %32
    • Unscrew the seven screws located on the back of the device.
  2. ThinkPad X1 Carbon Fingerprint Reader Replacement: passo 2, imagem 1 %32
    • Slide the plastic opening tool along the edge of the device to separate the keyboard tray.
  3. ThinkPad X1 Carbon Fingerprint Reader Replacement: passo 3, imagem 1 %32
    • Flip the device over and open it to lift the keyboard tray from the body of the device.
  4. ThinkPad X1 Carbon Fingerprint Reader Replacement: passo 4, imagem 1 %32
    • Use the plastic opening tool to gently release the ribbon cable attached to the keyboard.
    • You may now place the device off to the side. The rest of the repair takes place on the keyboard tray.
  5. ThinkPad X1 Carbon Fingerprint Reader Replacement: passo 5, imagem 1 %32
    • Locate the Fingerprint Reader and metal frame on the left side of the keyboard tray.
  6. ThinkPad X1 Carbon Fingerprint Reader Replacement: passo 6, imagem 1 %32
    • Unscrew the two silver screws to remove the metal frame.
  7. ThinkPad X1 Carbon Fingerprint Reader Replacement: passo 7, imagem 1 %32
    • Remove the ribbon cable connected to the board.
    • Remove and Replace the Fingerprint Reader board and metal frame.
    • This connection does not have a lock, please pull the ribbon away from the board. Do not attempt to lift the connection.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Duração total: 2,319
