Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
You will learn how to open the ThinkPad X1 Carbon and replace the battery.
O que você precisa
Gently remove battery connector bu pushing with the spudger in the direction of the arrow.
Remove four screws holding battery in place and remove battery.
9 outras pessoas executaram este guia.
3 comentários
bonjour,
depuis que j’ai changé la batterie, elle ne charge plus… j’ai remis celle d’origine, idem…
Une idée?
merci d’avance.
Bonjour,
J’ai le même phénomène que celui décrit plus haut par Franck D’ALOIA. La batterie de remplacement indique 100% de charge mais ne tient que 10min tout au plus.
Une idée ??
Merci à vous
Minor correction to step #3 - the text says "remove 4 screws", but reality - and the photo - is that there are five screws.
Important: Note that the center one in the circular hole in the battery (under the trackpad) is a shorter length than the others.
