Ir para o conteúdo principal
ThinkPad X1 Carbon Battery Replacement
O que você precisa
  1. ThinkPad X1 Carbon Battery Replacement, Battery: passo 1, imagem 1 %32
    • Unscrew the seven screws located on the back of the device
  2. ThinkPad X1 Carbon Battery Replacement: passo 2, imagem 1 %32
    • Slide the plastic the spudger along the edge of the device to separate the keyboard tray.
  3. ThinkPad X1 Carbon Battery Replacement: passo 3, imagem 1 %32
    • Flip the device over and open it to lift the keyboard tray from the body of the device .
  4. ThinkPad X1 Carbon Battery Replacement: passo 4, imagem 1 %32
    • Gently release the ribbon cable attached to the keyboard.
    • Gently Place keyboard tray to side.
  5. ThinkPad X1 Carbon Battery Replacement: passo 5, imagem 1 %32
    • Unscrew the 4 screws holding the battery in place.
  6. ThinkPad X1 Carbon Battery Replacement: passo 6, imagem 1 %32
    • Unlock and remove the ribbon cable running over the top of the battery.
  7. ThinkPad X1 Carbon Battery Replacement: passo 7, imagem 1 %32
    • Gently pull the battery connection from the motherboard .
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 318
