Ir para o conteúdo principal
ThinkPad X1 Carbon 1st Gen Fan Replacement
O que você precisa
  1. ThinkPad X1 Carbon 1st Gen Fan Replacement, Remove rear screws: passo 1, imagem 1 %32
    • Turn the laptop upside down, with the screen hinge away from you. Using the 0 size Phillips screwdriver, remove the 7 screws.
  2. ThinkPad X1 Carbon 1st Gen Fan Replacement, Open keyboard: passo 2, imagem 1 %32
    • Turn the laptop right side up, and open the screen. Slide the plastic the spudger along the edge of the device to separate the keyboard tray. There are 4 catches, two on the top and two on the bottom.
  3. ThinkPad X1 Carbon 1st Gen Fan Replacement, Open keyboard: passo 3, imagem 1 %32
    • Gently lift the keyboard away from you, as you would open the screen. The cable connecting the keyboard to the chassis is at the top. It will want to shift slightly to the right as you open it to account for the cable.
  4. ThinkPad X1 Carbon 1st Gen Fan Replacement, Remove keyboard: passo 4, imagem 1 %32
    • Gently pry away the keyboard connector from the chassis, and set the keyboard aside.
  5. ThinkPad X1 Carbon 1st Gen Fan Replacement, Remove CPU fan screws: passo 5, imagem 1 %32
    • Locate the fan on the left side of the exposed device.
    • Remove the 4 screws using the 00 size Phillips screwdriver, in the order detailed on the CPU, starting at the top left.
    • Next, the CPU fan cable, circled in red...
  6. ThinkPad X1 Carbon 1st Gen Fan Replacement, Remove CPU fan cable: passo 6, imagem 1 %32
    • Gently lift the CPU fan cable socket latch, and pull the cable to the left to remove.
  7. ThinkPad X1 Carbon 1st Gen Fan Replacement, Clean socket, CPU: passo 7, imagem 1 %32 ThinkPad X1 Carbon 1st Gen Fan Replacement, Clean socket, CPU: passo 7, imagem 2 %32
    • Clean the CPU with isopropyl alcohol, and the dust catcher for any debris/dust.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 18
Duração total: 2,105
