Ir para o conteúdo principal
ThinkPad Edge E31 Underside Disassembly
O que você precisa
  1. ThinkPad Edge E31 Underside Disassembly, Battery: passo 1, imagem 1 %32
    • There are two two locks for the battery, one on the left and one on the right.
    • Slide the left lock to the left.
  2. ThinkPad Edge E31 Underside Disassembly: passo 2, imagem 1 %32
    • Slide and hold the right battery lock to the right.
    • While holding the right battery lock, slide the battery up to remove it from the laptop.
  3. ThinkPad Edge E31 Underside Disassembly, ThinkPad Edge E31 Underside Disassembly: passo 3, imagem 1 %32
    • The battery should be removed before accessing any internal components, and you should ground yourself before handling internal components.
    • Unscrew the 5 screws holding the back on. These screws will unscrew from the laptop, but will remain secured to the back plate even when fully loosened. Once unscrewed, the plate can be removed.
Conclusão
Riley
Membro desde: 03/19/17
601 Reputação
Autoria de 6 guias
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 363
