Introdução
If it seems that an element of your scroll wheel is busted, it may need replacing. This guide will outline all the necessary steps to swap out a defective scroll wheel. With all the required parts and tools in hand, this guide should take but minutes to complete. Once finished, the scroll wheel for your Thermaltake Theron Plus Smart Mouse should be in working order.
O que você precisa
Remove the plastic cover and pack of weights.
Remove the two 1.0 mm foam covers with tweezers.
Peel away the plastic screw cover with tweezers.
Grasp the scroll wheel and wiggle it out in the direction opposite the socket.
