Ir para o conteúdo principal
Thermaltake Theron Plus 5-pin USB Cord Replacement
O que você precisa
  1. Thermaltake Theron Plus 5-pin USB Cord Replacement, Top cover: passo 1, imagem 1 %32 Thermaltake Theron Plus 5-pin USB Cord Replacement, Top cover: passo 1, imagem 2 %32 Thermaltake Theron Plus 5-pin USB Cord Replacement, Top cover: passo 1, imagem 3 %32
    • Remove the plastic cover and pack of weights.
    • Remove the two 1.0 mm foam covers with tweezers.
    • Peel away the plastic screw cover with tweezers.
  2. Thermaltake Theron Plus 5-pin USB Cord Replacement: passo 2, imagem 1 %32 Thermaltake Theron Plus 5-pin USB Cord Replacement: passo 2, imagem 2 %32
    • Remove the four 1.0 mm screws with a Ph #1 screwdriver.
    • Gently remove the top of the mouse.
  3. Thermaltake Theron Plus 5-pin USB Cord Replacement, 5-pin USB Cord: passo 3, imagem 1 %32 Thermaltake Theron Plus 5-pin USB Cord Replacement, 5-pin USB Cord: passo 3, imagem 2 %32 Thermaltake Theron Plus 5-pin USB Cord Replacement, 5-pin USB Cord: passo 3, imagem 3 %32
    • Locate the 5-pin connector on the mouse's motherboard.
    • Use the tweezers to carefully pull the 5-pin connector off. Do this by grasping the connector and wiggling it back and forth until it is off.
    • Once removed, place new 5-pin connector on in the same way.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 605
