Introdução
The Sharper Image Literati Tablet may need the SD port replaced. The SD port replacement for The Sharper Image Tablet can be done in approximately 30 minutes to a hour. The most difficult steps are those pertaining to screw removal.
O que você precisa
Wedge plastic spudger tool between the back panel and the body of device.
Pry apart the back panel and the device.
Ferramenta utilizada nesse passo:Plastic Cards$2.99
Gently wedge a spudger or thin plastic card between the battery and the body of device. Work the spudger or card along the length of the battery to free it from the adhesive.
Use a Phillips #00 screwdriver to remove the fifteen 4mm screws from the silver peripheral edging.
