Ir para o conteúdo principal
The Claw Battery Replacement
O que você precisa
  1. The Claw Battery Replacement, Batteries: passo 1, imagem 1 %32
    • Hold The Claw machine upright so that the controls are facing you.
  2. The Claw Battery Replacement: passo 2, imagem 1 %32
    • Turn the device upside down keeping the controls facing in your direction.
  3. The Claw Battery Replacement: passo 3, imagem 1 %32
    • Locate the battery compartment door on the bottom cover of The Claw.
    • Loosen the screw from the battery compartment door with your phillips head screwdriver.
  4. The Claw Battery Replacement: passo 4, imagem 1 %32
    • Open the door and insert the 3 D-cell batteries using the correct configuration that is labeled on the inside of the compartment.
    • If the batteries are not placed in the right configuration the device will not operate. make sure to identify positive and negative sides of the battery and follow the configuration on the device.
Conclusão
Uma outra pessoa concluiu este guia.
Alain Pierre
Membro desde: 03/22/16
1.188 Reputação
Autoria de 9 guias
Equipe
UMass Dartmouth, Team 4-8, Catania Spring 2016 Membro de UMass Dartmouth, Team 4-8, Catania Spring 2016
UMASSD-CATANIA-S16S4G8
Membros da 3
Autoria de 18 guias
Um comentário
daiobn ht45o9iyjugggjvj nvj vnv jnkrfdoelcbigvfcofrbbvfgb4vg3rcf2edebb
Jennifer Mateo - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 33
Duração total: 3,436
