Ir para o conteúdo principal
The Beatles Rock Band Hofner Bass Whammy Bar Replacement
O que você precisa
  1. The Beatles Rock Band Hofner Bass Whammy Bar Replacement, Back Plate: passo 1, imagem 1 %32
    • Flip the bass onto its backside, so that the strummer is facing the table and the battery compartment is facing you.
    • Use a J1 Phillips head screwdriver to remove ten 5mm short screws.
    • Use a J1 Phillips head screwdriver to remove four 5mm long screws.
  2. The Beatles Rock Band Hofner Bass Whammy Bar Replacement: passo 2, imagem 1 %32
    • Flip the bass to the front, with the strummer and fret buttons facing you.
    • Use a J1 Phillips head screwdriver to remove two 10mm silver, short screws.
  3. The Beatles Rock Band Hofner Bass Whammy Bar Replacement: passo 3, imagem 1 %32 The Beatles Rock Band Hofner Bass Whammy Bar Replacement: passo 3, imagem 2 %32
    • Flip the bass on its back again, so that the strummer is facing down and the battery compartment is facing you.
    • Pull off the back whole panel so that the bass is now open.
  4. The Beatles Rock Band Hofner Bass Whammy Bar Replacement, Whammy Bar: passo 4, imagem 1 %32
    • Use J1 Phillips screwdriver to remove the four 10mm screws on the whammy bars black cover.
  5. The Beatles Rock Band Hofner Bass Whammy Bar Replacement: passo 5, imagem 1 %32
    • Remove the black cover.
    • Now the white whammy bar underneath is visible.
  6. The Beatles Rock Band Hofner Bass Whammy Bar Replacement: passo 6, imagem 1 %32 The Beatles Rock Band Hofner Bass Whammy Bar Replacement: passo 6, imagem 2 %32
    • Use a J1 Philips head screwdriver to remove one 10mm screw.
    • This will unscrew the electrical connection between the whammy bar and the blue circuit board.
    • Remove the electrical connector.
  7. The Beatles Rock Band Hofner Bass Whammy Bar Replacement: passo 7, imagem 1 %32
    • Remove the whammy bar, since nothing should be connecting to the guitar anymore.
Conclusão
Jacob
Membro desde: 01/25/17
601 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 8-4, Banghart Winter 2017 Membro de Cal Poly, Team 8-4, Banghart Winter 2017
CPSU-BANGHART-W17S8G4
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 652
