Introdução
Through this guide you will learn how to replace the strummer in a Rock Band Beatles Hofner Bass.
O que você precisa
Flip the bass onto its backside, so that the strummer is facing the table and the battery compartment is facing you.
Use a J1 Phillips head screwdriver to remove ten 5mm short screws.
Use a J1 Phillips head screwdriver to remove four 5mm long screws.
Use a J1 Phillips head screwdriver to remove the four 10mm screws at the corners of the black casing.
