Introdução
This guide is for how to replace the directional pad on the Rock Band Beatles Hofner Bass.
O que você precisa
Flip the bass onto its backside, so that the strummer is facing the table and the battery compartment is facing you.
Use a J1 Phillips head screwdriver to remove ten 5mm short screws.
Use a J1 Phillips head screwdriver to remove four 5mm long screws.
Use a J1 Phillips screwdriver to remove the six screws 10mm around the brown button cover.
