Introdução
This repair guide requires you to be more careful when it come to working around the wires that you will find. You will also need to unscrew some screws in the process. Be careful when removing the module and pay extra attention to where you put your screws.
O que você precisa
Remove the four Phillips size J1 screws from the corners of the bottom module.
Quase terminado!
Conclusão
