Ir para o conteúdo principal
The Beatles Rock Band Drum Set Drum Pad Replacement
O que você precisa
  1. The Beatles Rock Band Drum Set Drum Pad Replacement, Drum Pad: passo 1, imagem 1 %32 The Beatles Rock Band Drum Set Drum Pad Replacement, Drum Pad: passo 1, imagem 2 %32
    • Pry the drum pad off of the drum set.
    • This will take significant force, but the rubber on the drum pad can withstand the force.
  2. The Beatles Rock Band Drum Set Drum Pad Replacement: passo 2, imagem 1 %32 The Beatles Rock Band Drum Set Drum Pad Replacement: passo 2, imagem 2 %32
    • Remove the small wire clip shown in the picture.
    • If this wire is already disconnected, that is most likely the cause for the drum pad not working.
  3. The Beatles Rock Band Drum Set Drum Pad Replacement: passo 3, imagem 1 %32
    • Remove the four Phillips size J0 screws supporting the hit sensor.
    • There is a small plastic disk and a spring in the support; be sure not to lose it.
  4. The Beatles Rock Band Drum Set Drum Pad Replacement: passo 4, imagem 1 %32
    • The sensor can be peeled off of the drum pad.
Conclusão
Zach Richter
Membro desde: 01/24/17
549 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 13-3, Banghart Winter 2017 Membro de Cal Poly, Team 13-3, Banghart Winter 2017
CPSU-BANGHART-W17S13G3
Membros da 4
Autoria de 5 guias
Um comentário
Where can you buy replacement sensor?
Barry Howard - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 15
Últimos 30 dias: 63
Duração total: 7,926
