Introdução
In this guide we will show how to remove the display to replace it if broken.
- incomplete we currently do not know how to do this and can find no information on it
O que você precisa
Grab the back of the calculator with one hand and the cover with the other.
Pull the cover off from one of the sides for easy removal.
"Locking Tab"
To remove the back cover, slide the cover away from the locking tab towards the bottom of the calculator until the cover no longer slides.
Then with the front of the calculator facing down, pull up on the back cover.
The calculator should now be orientated with the front facing down, as shown in picture 2.
Remove the bottom batteries by pressing the battery towards you while pulling it out from the far end.
After the bottom battery has been removed push or slide the other(top) battery towards you until it is fully exposed in the battery slot.
Now simply remove the battery.
Using a Philips Screwdriver #00 unscrew the twelve 11.8mm screws shown in the picture and located on the back of the calculator.
Now pull up on the back cover of the calculator while holding the rest of it flat on a surface.
Some models might require removing the two battery screws before the back cover can be pulled up. These screws are somewhat smaller than the others but can easily be removed with the same screwdriver.
Pull the motherboard up while holding the rest of the calculator firmly in place
The motherboard has now separated from the rest of the calculator
Using a #00 Philip Screwdriver remove the screw located on the left side of a spring-like object located near the center of the motherboard.
Tilt the calculator up from the front so that you can see the LCD screen
Finish removing the black tape on this side of the motherboard.
Hi.
Really, if you remove the connector strip, the bonding substance is removed, even the electrical cables will be broken. They are so delicate
I have this experience, and it's impossible to rebond the ancient connector band.
The main question is: Where to adquire a new connector band?.
Thx
Hello, is there any information which display is used? I would need to change it, but don't find anywhere spare parts... Thx
Uma outra pessoa concluiu este guia.
