Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
In this guide we will be showing how to remove the TI-92's back case to get to inner components.
O que você precisa
Grab the back of the calculator with one hand and the cover with the other.
Pull the cover off from one of the sides for easy removal.
"Locking Tab"
To remove the back cover, slide the cover away from the locking tab towards the bottom of the calculator until the cover no longer slides.
Then with the front of the calculator facing down, pull up on the back cover.
The calculator should now be orientated with the front facing down, as shown in picture 2.
Remove the bottom batteries by pressing the battery towards you while pulling it out from the far end.
After the bottom battery has been removed push or slide the other(top) battery towards you until it is fully exposed in the battery slot.
Now simply remove the battery.
Using a Philips Screwdriver #00 unscrew the twelve 11.8mm screws shown in the picture and located on the back of the calculator.
