Ir para o conteúdo principal
Texas Instruments TI-83 Plus Motherboard & Screen Replacement
O que você precisa
  1. Texas Instruments TI-83 Plus Motherboard & Screen Replacement, Backup Battery: passo 1, imagem 1 %32 Texas Instruments TI-83 Plus Motherboard & Screen Replacement, Backup Battery: passo 1, imagem 2 %32
    • Remove the battery cover.
    • Remove the AAA batteries from the calculator.
  2. Texas Instruments TI-83 Plus Motherboard & Screen Replacement: passo 2, imagem 1 %32
    • Remove the 5mm Philips #00 screw holding backup battery cover.
    • Remove the backup battery cover.
  3. Texas Instruments TI-83 Plus Motherboard & Screen Replacement: passo 3, imagem 1 %32
    • Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
    • Be careful, the backup battery is spring loaded and may shoot up when you remove it.
  4. Texas Instruments TI-83 Plus Motherboard & Screen Replacement, Back Case: passo 4, imagem 1 %32
    • Unscrew the six 7.5mm T6 screws on the back case. You will need to use a screwdriver with a long and skinny head.
  5. Texas Instruments TI-83 Plus Motherboard & Screen Replacement: passo 5, imagem 1 %32 Texas Instruments TI-83 Plus Motherboard & Screen Replacement: passo 5, imagem 2 %32
    • Pry back case off. Insert the plastic opening tool in the track for the protective cover and pry the halves of the case apart.
  6. Texas Instruments TI-83 Plus Motherboard & Screen Replacement, Motherboard & Screen: passo 6, imagem 1 %32 Texas Instruments TI-83 Plus Motherboard & Screen Replacement, Motherboard & Screen: passo 6, imagem 2 %32
    • Keep the screen face-down during this step. Only the motherboard is attached to the face-plate and the screen may fall out.
    • Remove the eight (8) 5mm Philips #00 screws on the motherboard.
  7. Texas Instruments TI-83 Plus Motherboard & Screen Replacement: passo 7, imagem 1 %32 Texas Instruments TI-83 Plus Motherboard & Screen Replacement: passo 7, imagem 2 %32
    • Carefully remove the motherboard and screen. Grab the board by its side with one hand and the screen with the other. Carefully lift the two parts up.
    • Keep the face-plate face-down to prevent the keys from falling out.
Conclusão
20 outras pessoas executaram este guia.
Kevin
Membro desde: 10/02/12
479 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 18-37, Regan Fall 2012 Membro de Cal Poly, Team 18-37, Regan Fall 2012
CPSU-REGAN-F12S18G37
Membros da 5
Autoria de 5 guias
15 comentários
Does anyone have any advice on acquiring replacement screens for the TI series? I was considering buying broken TIs on e-bay, but that may be unreliable.
Neil Cammardella - Responder
Fixing TI83+'s is becoming addictive. Google Cemetech Forum on the net and see how he removes the screen from the Mother Board and solders wires permanently. I might add that he tests for resistance (ohms) first to determine if in fact that is where the problems exist. If I read between the lines, he tends to think that the screen/mother board ribbon cable is the primary culprit behind problems with the TI83's
shrinertom@yahoo.com
shrinertom -
My TI-83 Plus, the screen has turned Black, like to know where to send it to have it repaired e-mail address, (BagManOne@ecite.com)
Richard Brown - Responder
Nothing is broken, the screen has turned Black, need to send it off and have it fixed, I can not do it my self because of the condition of my hands
Richard Brown -
It may not be broken. Try adjusting the screen contrast down.
Matthew Johnson -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 35
Últimos 30 dias: 119
Duração total: 49,221
