Introdução
The keyboard mat is what makes contacts with the motherboard. If the keys are not working very well then the mat may need replacing.
O que você precisa
Remove the battery cover.
Remove the AAA batteries from the calculator.
Unscrew the six 7.5mm T6 screws on the back case. You will need to use a screwdriver with a long and skinny head.
Uma outra pessoa concluiu este guia.
