Ir para o conteúdo principal
Texas Instruments TI-83 Plus Keyboard Mat Replacement
O que você precisa
  1. Texas Instruments TI-83 Plus Keyboard Mat Replacement, Backup Battery: passo 1, imagem 1 %32 Texas Instruments TI-83 Plus Keyboard Mat Replacement, Backup Battery: passo 1, imagem 2 %32
    • Remove the battery cover.
    • Remove the AAA batteries from the calculator.
    Pergunte ao FixBot
    Comentar
  2. Texas Instruments TI-83 Plus Keyboard Mat Replacement: passo 2, imagem 1 %32
    • Remove the 5mm Philips #00 screw holding backup battery cover.
    • Remove the backup battery cover.
    Pergunte ao FixBot
    Comentar
  3. Texas Instruments TI-83 Plus Keyboard Mat Replacement: passo 3, imagem 1 %32
    • Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
    • Be careful, the backup battery is spring loaded and may shoot up when you remove it.
    Pergunte ao FixBot
    Comentar
  4. Texas Instruments TI-83 Plus Keyboard Mat Replacement, Back Case: passo 4, imagem 1 %32
    • Unscrew the six 7.5mm T6 screws on the back case. You will need to use a screwdriver with a long and skinny head.
    Pergunte ao FixBot
    Comentar
  5. Texas Instruments TI-83 Plus Keyboard Mat Replacement: passo 5, imagem 1 %32 Texas Instruments TI-83 Plus Keyboard Mat Replacement: passo 5, imagem 2 %32
    • Pry back case off. Insert the plastic opening tool in the track for the protective cover and pry the halves of the case apart.
    Pergunte ao FixBot
    Comentar
  6. Texas Instruments TI-83 Plus Keyboard Mat Replacement, Motherboard & Screen: passo 6, imagem 1 %32 Texas Instruments TI-83 Plus Keyboard Mat Replacement, Motherboard & Screen: passo 6, imagem 2 %32
    • Keep the screen face-down during this step. Only the motherboard is attached to the face-plate and the screen may fall out.
    • Remove the eight (8) 5mm Philips #00 screws on the motherboard.
    Pergunte ao FixBot
    Comentar
  7. Texas Instruments TI-83 Plus Keyboard Mat Replacement: passo 7, imagem 1 %32 Texas Instruments TI-83 Plus Keyboard Mat Replacement: passo 7, imagem 2 %32
    • Carefully remove the motherboard and screen. Grab the board by its side with one hand and the screen with the other. Carefully lift the two parts up.
    • Keep the face-plate face-down to prevent the keys from falling out.
    Pergunte ao FixBot
    Comentar
  8. Texas Instruments TI-83 Plus Keyboard Mat Replacement, Keyboard Mat: passo 8, imagem 1 %32 Texas Instruments TI-83 Plus Keyboard Mat Replacement, Keyboard Mat: passo 8, imagem 2 %32
    • Remove light gray rubber keyboard mat.
    • Keep your calculator face down to ensure the individual keys do not fall out.
    Pergunte ao FixBot
    Comentar
  9. Texas Instruments TI-83 Plus Keyboard Mat Replacement: passo 9, imagem 1 %32
    • Clean the contacts on the keyboard with a soft cloth.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
corey
Membro desde: 10/02/12
11 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 18-37, Regan Fall 2012 Membro de Cal Poly, Team 18-37, Regan Fall 2012
CPSU-REGAN-F12S18G37
5 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 15
Últimos 30 dias: 58
Ao todo: 5,096
