Ir para o conteúdo principal
Texas Instruments TI-83 Plus Backup Battery Replacement
O que você precisa
  1. Texas Instruments TI-83 Plus Backup Battery Replacement, Backup Battery: passo 1, imagem 1 %32 Texas Instruments TI-83 Plus Backup Battery Replacement, Backup Battery: passo 1, imagem 2 %32
    • Remove the battery cover.
    • Remove the AAA batteries from the calculator.
    Pergunte ao FixBot
    Comentar
  2. Texas Instruments TI-83 Plus Backup Battery Replacement: passo 2, imagem 1 %32
    • Remove the 5mm Philips #00 screw holding backup battery cover.
    • Remove the backup battery cover.
    Pergunte ao FixBot
    Comentar
  3. Texas Instruments TI-83 Plus Backup Battery Replacement: passo 3, imagem 1 %32
    • Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
    • Be careful, the backup battery is spring loaded and may shoot up when you remove it.
    Pergunte ao FixBot
    Comentar
Conclusão
Clay
Membro desde: 10/01/12
38 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 18-37, Regan Fall 2012 Membro de Cal Poly, Team 18-37, Regan Fall 2012
CPSU-REGAN-F12S18G37
5 Membros
Autoria de 5 guias
2Comentários do guia
Will this wipe the memory?
John Osborne - Responder Compartilhar
Yes I found one and have been trying to get it together for a high schooler I had one when I took trig in college and it was very helpful
Jack Irvin - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 25
Últimos 30 dias: 83
Ao todo: 23,976
