Ir para o conteúdo principal
Texas Instruments TI-83 Plus Back Case Replacement
O que você precisa
  1. Texas Instruments TI-83 Plus Back Case Replacement, Backup Battery: passo 1, imagem 1 %32 Texas Instruments TI-83 Plus Back Case Replacement, Backup Battery: passo 1, imagem 2 %32
    • Remove the battery cover.
    • Remove the AAA batteries from the calculator.
  2. Texas Instruments TI-83 Plus Back Case Replacement: passo 2, imagem 1 %32
    • Remove the 5mm Philips #00 screw holding backup battery cover.
    • Remove the backup battery cover.
  3. Texas Instruments TI-83 Plus Back Case Replacement: passo 3, imagem 1 %32
    • Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
    • Be careful, the backup battery is spring loaded and may shoot up when you remove it.
  4. Texas Instruments TI-83 Plus Back Case Replacement, Back Case: passo 4, imagem 1 %32
    • Unscrew the six 7.5mm T6 screws on the back case. You will need to use a screwdriver with a long and skinny head.
  5. Texas Instruments TI-83 Plus Back Case Replacement: passo 5, imagem 1 %32 Texas Instruments TI-83 Plus Back Case Replacement: passo 5, imagem 2 %32
    • Pry back case off. Insert the plastic opening tool in the track for the protective cover and pry the halves of the case apart.
Conclusão
8 outras pessoas executaram este guia.
Jared
Membro desde: 10/02/12
151 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 18-37, Regan Fall 2012 Membro de Cal Poly, Team 18-37, Regan Fall 2012
CPSU-REGAN-F12S18G37
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 19
Duração total: 9,842
